查看: 869|回复: 0
EVAL2293Q演示板
  • 签到天数: 361 天
    发表于 2014-2-25 13:15:02 | 显示全部楼层 |阅读模式
    EVAL2293Q演示板集成二极管L2293Q推挽四通道驱动器。该L2293Q设计用于驱动电感性负载,如直流和步进电机或继电器和螺线管。该开发板实现了典型的应用程序,它可以作为一个参考设计用于驱动两相双极步进电机的电流可达0.6 A直流,多直流电动机和广泛的感性负载。This application note describes the EVAL2293Q demonstration board for the L2293Q pushpull four channel driver with integrated diodes. The L2293Q is designed to drive inductive loads such as DC and stepping motors, or relays and solenoids. The board implements a typical application which can be used as a reference design to drive two-phase bipolar stepper motors with currents up to 0.6 A DC, multiple DC motors and a wide range of inductive loads.Housed in a QFN 5 x 5 mm 32-lead package, the small footprint of the L2293Q makes the PCB very compact (24.5 x 24.5 mm).
    EVAL2293Q App Note.pdf
    358.78 KB, 下载次数: 0
    L2293Q.pdf
    275.71 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:52 , Processed in 0.123862 second(s), 16 queries , MemCache On.
