查看: 195|回复: 0
STEVAL-ISB001V1演示板
  • 签到天数: 361 天
    发表于 2014-2-22 15:06:30 | 显示全部楼层 |阅读模式
    STEVAL-ISB001V1演示板是一个振铃扼流转换器(RCC)为基础,一步接一步的手机电池充电器。The STEVAL-ISB001V1 demonstration board is a ringing choke converter (RCC)-based, step-bystep cell phone battery charger.The RCC is essential to the self-oscillating flyback converter, and operates within the discontinuous conduction mode (DCM) and continuous conduction mode (CCM) boundaries without noticeable reverse recovery of the output rectifying diodes.RCC control is achieved by using discrete components to control the peak current mode, so the overall RCC cost is relatively low compared to the conventional pulse width modulation (PWM) IC flyback converter. As a result, RCC is widely used for low-power applications in industry and home appliances as a simple and cost-effective solution.
    STEVAL-ISB001V1 Data Brief.pdf
    131.91 KB, 下载次数: 0
    STx1(L)NK60Z Series.pdf
    460.96 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:52 , Processed in 0.116947 second(s), 16 queries , MemCache On.
