查看: 277|回复: 0
EVAL6208N评估板
  • 签到天数: 361 天
    发表于 2014-2-22 14:50:46 | 显示全部楼层 |阅读模式
    EVAL6208N评估板是围绕L6208在POWERDIP包。它实现了一个典型的步进电机驱动器应用。The EVAL6208N is built around L6208 in PowerDip package. It implements a typical stepper motor driver application. Screw connectors provide connection to motor supply rail and 5 V reference for the logic inputs, as well as the four outputs to motor windings. EVAL6208N can be hooked-up to practiSPIN interface board (EVALpractiSPIN) through a 34-pin connector. It is also possible to run board in stand-alone mode: four switches are used to set the direction of the rotation, the stepping sequence and the current decay style, while four potentiometers set the L6208 reference voltage and off-time for the PWM current control; external reference voltages can be provided by a PWM output of a µC.
    L6208.pdf
    463.91 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:44 , Processed in 0.116619 second(s), 16 queries , MemCache On.
