查看: 681|回复: 0
STEVAL-CCA004V1评估板
  • 签到天数: 361 天
    发表于 2014-2-22 14:10:04 | 显示全部楼层 |阅读模式
    STEVAL-CCA004V1评估板是基于TSH120视频缓冲器。该TSH120包括一个电压反馈放大器6 dB的内部增益,轨到轨输出,内部输入偏置和SAG校正。掉电功能提供了睡眠模式的超低功耗。This evaluation board is based on the TSH120 video buffer. The TSH120 includes a voltage feedback amplifier with an internal gain of 6 dB, rail-to-rail output, internal input biasing and SAG correction. A power-down function provides a sleep mode with ultra low power consumption.
    STEVAL-CCA004V1 Data Brief.pdf
    78.33 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:51 , Processed in 0.111683 second(s), 16 queries , MemCache On.
