查看: 176|回复: 0
STEVAL-ISA076V2演示板
  • 签到天数: 361 天
    发表于 2014-2-22 13:51:38 | 显示全部楼层 |阅读模式
    STEVAL-ISA076V2演示板是基于L6924U,这是一个完全集成的单片电池充电器,专用于单节锂离子/聚合物电池组。它是适用于空间受限的应用,如PDA,手持设备,移动电话和数码相机,是个理想的解决方案。The STEVAL-ISA076V2 demonstration board is based on the L6924U which is a fully monolithic battery charger dedicated to single-cell LiIon/Polymer battery packs. It is the ideal solution for space-limited applications, such as PDAs, handheld equipment, cellular phones, and digital cameras.When an external voltage regulated adapter or USB port is used, the L6924U works in linear mode, and charges the battery in a constant current/constant voltage (CC/CV) profile.Moreover, when a current-limited adapter is used, the device can operate in Quasi-Pulse Mode, dramatically reducing the power dissipation.
    STEVAL-ISA076V2 Data Brief.pdf
    97.03 KB, 下载次数: 0
    L6924U.pdf
    822.39 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:42 , Processed in 0.115026 second(s), 16 queries , MemCache On.
