TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
STEVAL-PCC004V1演示板由一个微型B-USB接口,一个USB控制器,USB收发器,2个2到4解复用器和所有所需的分立元件(上拉电阻,串联电阻和电源电容)。该演示板从USB微型B供电或,任选地,从外部供给。收发器STUSB02连接在微控制器的USB通信线路。For demonstration purposes, the USB microcontroller used is the ST72F63BE2 8-bit microcontroller. The STUSB03 connected to a USB controller is ideal for use in mobile phones, digital cameras, printers, PDAs, etc. All hardware omponents except the transceiver IC are the same for the STEVAL-PCC003V1 and STEVALPCC004V1 demonstration boards. The demonstration board is comprised of one mini-B USB connector, a USB controller, a USB transceiver, two 2-to-4 demultiplexers and all required discrete components (pull-up resistors, series resistors and power supply capacitors). The device can be configured through a set of jumpers and the main signals can be accessed through test points. The demonstration board is powered from a USB mini-B or, optionally, from an external supply. The transceiver STUSB02 is connected at the USB communication lines of the microcontroller. |
