查看: 179|回复: 0
STEVAL-SPMD150V2演示板
  • 签到天数: 361 天
    发表于 2014-2-21 16:05:45 | 显示全部楼层 |阅读模式
    STEVAL-SPMD150V2演示板是专为评定性能和SPMD150STP的功能模块。该板的工作原理与PractiSPIN™硬件和PractiSPIN™一起使用。This STEVAL-SPMD150V2 demonstration board is designed for evaluating the performance and the features of the SPMD150STP module. The board works in conjunction with the PractiSPIN™ HW and the PractiSPIN™.spmd SW, which allow the user to operate with the SPMD150STP module.The SPMD150STP is part of the EASY POWER™ series of fully integrated modules designed to drive bipolar permanent-magnet stepper motors.All EASY POWER modules offer an easy-to-use, fully-protected solution to implement precise position control, with high torque at rest, and without the need for external components. The module operates over a wide 12 V to 40 V input voltage range and supports an output maximum current of 1.5 A.
    STEVAL-SPMD150V2 Data Brief.pdf
    92.46 KB, 下载次数: 0
    GMT+8, 2024-11-26 00:53 , Processed in 0.125823 second(s), 16 queries , MemCache On.
