TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
STEVAL-CCA010V1演示板的目的是评估该TSH122,是使用一个电压反馈放大器,具有6分贝,输出轨至轨,内部输入的DC-shift和SAG校正的内部增益视频缓冲。掉电功能允许切换到睡眠模式的超低功耗。The demonstration board STEVAL-CCA010V1 is designed to evaluate the TSH122 that is a video buffer that uses a voltage feedback amplifier, with an internal gain of 6 dB, an output rail-to-rail, an internal input DC-shift and a SAG correction. A power-down function allows switching to a sleep mode with an ultra-low consumption.The TSH122 features a 6th-order internal reconstruction filter to attenuate the parasitic frequency of 27 MHz from the clock of the video DAC.The TSH122 is a single operator available in a tiny SC70 plastic package for space saving. |
