查看: 205|回复: 0
STEVAL-IPE017V1演示板
  • 签到天数: 361 天
    发表于 2014-2-21 14:11:13 | 显示全部楼层 |阅读模式
    STEVAL-IPE017V1演示板是一个0.5级,单相基于微处理器的仪表。该STEVAL-IPE017V1演示板有一个10-pin连接器,通过并行或串行编程器读出的数据被连接到微控制器或PC。The STEVAL-IPE017V1 demonstration board is a class 0.5, single-phase microprocessor-based meter for power line systems of Vnom = 140 to 300 VRMS, Inom/ Imax = 2/20 ARMS, flin = 45 to 65 Hz and Tamb = -40 to +85 °C. One shunt resistor is used for current sensing.The STEVAL-IPE017V1 demonstration board has a 10-pin connector to be interfaced to a microcontroller or to a PC through a parallel or serial programmer for reading data.
    STEVAL-IPE017V1 Brief.pdf
    163.62 KB, 下载次数: 0
    STEVAL-IPE0xxV1 User Manual.pdf
    388.98 KB, 下载次数: 0
    STPM10.pdf
    565.16 KB, 下载次数: 0
    GMT+8, 2024-11-26 00:56 , Processed in 0.104209 second(s), 16 queries , MemCache On.
