查看: 195|回复: 0
EVAL6206Q演示板
  • 签到天数: 361 天
    发表于 2014-2-21 13:40:02 | 显示全部楼层 |阅读模式
    EVAL6206Q演示板允许用户测试L6206Q功能。集成到L6206Q设备的双重全桥,可以用来驱动一个两相步进电机或四个直流电动机(单向)。The EVAL6206Q demonstration board allows the user to test the L6206Q functions. The dual full bridges integrated into the L6206Q device can be used to drive a single 2-phase stepper motor or up to four DC motors (unidirectional). The bridges can also operate in parallel mode. The board can be driven using the STEVAL-PCC009V2 demonstration board and the PractiSPIN 2 evaluation software.
    EVAL6206Q.pdf
    711.8 KB, 下载次数: 0
    L6206Q.pdf
    649.95 KB, 下载次数: 0
    GMT+8, 2024-11-26 00:35 , Processed in 0.109953 second(s), 16 queries , MemCache On.
