查看: 181|回复: 0
STEVAL-CCH002V1 HDMI和视频开关评估板
  • 签到天数: 361 天
    发表于 2014-2-20 15:24:16 | 显示全部楼层 |阅读模式
    STEVAL-CCH002V1 HDMI和视频开关评估板。该评估板分别演示了STMAV335和TMAV340的功能模拟视频开关和STHDMI002A和STDVE003A数字视频开关。This evaluation board demonstrates the functionalities of the STMAV335 and TMAV340analog video switches and the STHDMI002A and STDVE003A digital video switches, respectively.The purpose is to demonstrate the capabilities of ST's video switches and buffers (also making an appropriate use of the signal line protection devices in all I/O Lines) for both standard analog or high speed TMDS (Transition Minimized Differential Signaling) digital signals.Demonstration of the various devices is achieved by setting the appropriate jumpers on the evaluation board. All necessary I/O interface connectors applicable for each signal format are provided. Standard interconnects available on the market can be used with the evaluation board.
    STDVE003A.pdf
    842.43 KB, 下载次数: 0
    STEVAL-CCH002V1 Data Brief.pdf
    236.54 KB, 下载次数: 0
    GMT+8, 2024-11-26 01:28 , Processed in 0.116847 second(s), 16 queries , MemCache On.
