查看: 720|回复: 0
STEVAL-IPE009V1单相/多费率电能表
  • 签到天数: 361 天
    发表于 2014-2-20 14:58:00 | 显示全部楼层 |阅读模式
    STEVAL-IPE009V1单相/多费率电能表是以ST72321BR9和STPM14为基础的。该演示板实现了许多功能,可以用来作为评估和仪表应用,包括多资费管理,绝对和平均最高需求量计算,两种类型的防篡改管理,和电源故障管理发展的出发台。This demonstration board is an integrated system designed to provide the user with a complete, ready-to-use energy meter application. It is a medium-end solution for power metering, using the ST72F321BR9T6 microcontroller, the M41T94 RTC (real-time clock), the M95256 EEPROM and the STPM14 energy meter ASSP device.The multi-tariff energy meter demonstration board implements many features that can be used as a starting platform for evaluation and development of meter applications, including multi-tariff management, absolute and average maximum demand calculation, two types of tamper management, and power failure management.
    STPM1x.pdf
    1.36 MB, 下载次数: 0
    ST72321Bxx(x).pdf
    2.73 MB, 下载次数: 0
    STEVAL-IPE009V1 Data Brief.pdf
    173.51 KB, 下载次数: 0
    GMT+8, 2024-11-26 01:46 , Processed in 0.104107 second(s), 16 queries , MemCache On.
