查看: 157|回复: 0
STEVAL-ISF002V1演示板
  • 签到天数: 361 天
    发表于 2014-2-20 14:21:40 | 显示全部楼层 |阅读模式
    STEVAL-ISF002V1演示板作为一个平台,用于评估意法半导体STW23NM60N的MDmesh™功率MOSFET的能力,和TD352先进的IGBT/ MOSFET驱动器。The STEVAL-ISF002V1 demonstration board provides platform for evaluating the capabilities of STMicroelectronics’ STW23NM60N MDmesh™ power MOSFET, and the TD352 advanced IGBT/MOSFET driver.The board also demonstrates ST’s STM32F103ZE microcontroller in digital power factor corrector application. The performance of the MCU in this design is comparable to standard continuous-mode PFC dedicated monolithic ICs, while retaining sufficient microcontroller resources (such as program memory and CPU computational capability) to execute additional complex operations.The system is designed to offer high performance in terms of PF, THD and DC output voltage ripple. For less demanding applications, the size of power components on the PFC power board can
    STM32F103ZE User Manual.pdf
    1.65 MB, 下载次数: 0
    STEVAL-ISF002V1 Data Brief.pdf
    166.33 KB, 下载次数: 0
    GMT+8, 2024-11-26 01:46 , Processed in 0.124884 second(s), 16 queries , MemCache On.
