查看: 254|回复: 0
SB202开发套件
  • 签到天数: 361 天
    发表于 2014-2-20 13:44:00 | 显示全部楼层 |阅读模式
    SB202开发套件,用于爱特梅尔ATmega32HVB。这个装置是用串联一个或两个电池包制造,并设有独立的电池保护,以及非常精确的电压,电流和温度监控功能。该器件保护处于危险状态的电池组和周围环境,并从电池单元获得大部分能量。The SB202 is an evaluation and development kit for the Atmel ATmega32HVB. This device is made for battery packs with either one or two cells in series, and features autonomous battery protection as well as very accurate voltage, current and temperature monitoring capabilities. The device provides the means to protect the battery pack and surroundings from hazardous conditions and gain most energy from the Battery cells.
    GMT+8, 2024-11-26 01:24 , Processed in 0.110272 second(s), 15 queries , MemCache On.
