TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
AT89C51RD2开发套件中的AT89C51RD2是高性能CMOS Flash版本的80C51 CMOS单芯片8 - 位微控制器。它包含了代码和数据的64 - Kbyte闪存块。64 KB的闪存可以编程无论是在并行模式或串行模式与在ISP能力或软件。AT89C51RD2/ED2 is high performance CMOS Flash version of the 80C51 CMOS single chip 8-bit microcontroller. It contains a 64-Kbyte Flash memory block for code and for data.The 64-Kbytes Flash memory can be programmed either in parallel mode or in serial mode withthe ISP capability or with software. The programming voltage is internally generated from thestandard VCC pin.The AT89C51RD2/ED2 retains all of the features of the Atmel 80C52 with 256 bytes of internalRAM, a 9-source 4-level interrupt controller and three timer/counters. The AT89C51ED2 provides 2048 bytes of EEPROM for nonvolatile data storage.In addition, the AT89C51RD2/ED2 has a Programmable Counter Array, an XRAM of 1792bytes, a Hardware Watchdog Timer, SPI interface, Keyboard, a more versatile serial channelthat facilitates multiprocessor communication (EUART) and a speed improvement mechanism(X2 Mode).The fully static design of the AT89C51RD2/ED2 allows to reduce system power consumption bybringing the clock frequency down to any value, including DC, without loss of data.The AT89C51RD2/ED2 has 2 software-selectable modes of reduced activity and an 8-bit clockprescaler for further reduction in power consumption. In the Idle mode the CPU is frozen whilethe peripherals and the interrupt system are still operating. In the Power-down mode the RAM issaved and all other functions are inoperative.The added features of the AT89C51RD2/ED2 make it more powerful for applications that needpulse width modulation, high speed I/O and counting capabilities such as alarms, motor control,corded phones, and smart card readers. |
