查看: 213|回复: 0
PCF2127A时钟评估套件
  • 签到天数: 361 天
    发表于 2014-2-19 15:24:36 | 显示全部楼层 |阅读模式
    PCF2127A时钟评估套件,可以进行针对实时时钟进行精确的实验评估。The PCF2127AT1 is a CMOS2 Real Time Clock (RTC) and calendar with an integrated Temperature Compensated Crystal (Xtal) Oscillator (TCXO) and a 32.768 kHz quartz crystal optimized for very high accuracy and very low power consumption. The PCF2127AT has 512 bytes of general purpose static RAM, a selectable I2C-bus or SPI-bus, a backup battery switch-over circuit, a programmable watchdog function, a timestamp function, and many other features.
    PCF2127AT.pdf
    1.07 MB, 下载次数: 0
    OM11051_DS.pdf
    486.88 KB, 下载次数: 0
    GMT+8, 2024-11-26 01:54 , Processed in 0.115171 second(s), 16 queries , MemCache On.
