查看: 324|回复: 0
打印 上一主题 下一主题
TDA5051A照明控制演示板
  • 签到天数: 361 天
    跳转到指定楼层
    楼主
    发表于 2014-2-18 17:16:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    TDA5051A照明控制演示由一个主控制器和一个从照明控制器。主控制器采用高架板,它由LPC1114的单片机,TDA5051A PLM IC和电源管理电路。交流 - 直流转换器是用来提供13伏直流电源电压。主采用4×PCF8883电容式接近开关,以提供开/关,变得暗淡起来,暗淡了下来,并选择输出遥控照明从控制器。The TDA5051A lighting control demo consists of a master controller and a slave lighting controller. The master controller uses the High-Bay board, which consists of the LPC1114 microcontroller, the TDA5051A PLM IC, and power management circuitry. An AC-DC converter is used to provide +13 V DC supply voltage. The master employs 4 × PCF8883 capacitive proximity switches to provide On/Off, Dim Up, Dim Down, and Select outputs of the remote lighting slave controller. The slave controller consists of the High-Bay board, an AC-DC converter to provide +13 V supply voltage, and an LED array. Both the master and the slave are housed in a plastic box with 110 V AC power cords.
    TDA5051A Demo Brd OM13314 Manual.pdf
    2.92 MB, 下载次数: 0
    举报
    站长推荐上一条 4/4 下一条
    【预约参会三重礼】2025 瑞萨电子工业以太网技术日
    查看 »
    GMT+8, 2025-3-24 19:39 , Processed in 0.109905 second(s), 19 queries , MemCache On.
