TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
I²C FM +开发板套件OM13320是一个开发工具,它允许您轻松地实现和调试一个高达1 MHz(FM +)的硬件和软件的I²C系统。I²C Fm+ Development Board Kit OM13320 is a development tool which allows you to easily implement and debug both the hardware and software of an up to 1 MHz (Fm+) I²C system.特性:
- Explore the I²C-bus
- Run demonstrations of NXP’s I²C Fm+ Slaves and Bus Controllers
- Develop I²C Hardware
- Expand the kit with add-on I²C daughter cards
简介:Related products: GPIOPCA9670 - Remote 8-bit I/O expander for Fm+ I²C-bus with resetPCA9671 - Remote 16-bit I/O expander for Fm+ I²C-bus with resetPCA9672 - Remote 8-bit I/O expander for Fm+ I²C-bus with interrupt and resetPCA9673 - Remote 16-bit I/O expander for Fm+ I²C-bus with interrupt and resetPCA9674; PCA9674A - Remote 8-bit I/O expander for Fm+ I²C-bus with interruptPCA9675 - Remote 16-bit I/O expander for Fm+ I²C-bus with interruptPCA9698 - 40-bit Fm+ I²C-bus advanced I/O port with RESET, OE and INTBus ContollersPCA9629 - Fm+ I²C-bus stepper motor controllerPCA9661B - Parallel bus to 1 channel Fm+ I²C-bus controllerPCA9663B - Parallel bus to 3 channel Fm+ I²C-bus controllerPCA9665; PCA9665A - Fm+ parallel bus to I²C-bus controllerPCU9669B - Parallel bus to 1 channel Fm+ and 2 channel UFm I²C-bus controllerBus Buffers and ExtendersPCA9527 - 3-channel bidirectional bus extender for HDMI, I2C-bus and SMBusPCA9600 - Dual bidirectional bus bufferPCA9600 - Dual bidirectional bus bufferPCA9601 - Dual bidirectional bus bufferPCA9601 - Dual bidirectional bus bufferPCA9605 - Simple 2-wire bus bufferPCA9646 - Buffered 4-channel 2-wire bus switchPCA9617A - Level translating Fm+ I²C-bus repeaterLED ControllerPCA9622 - 16-bit Fm+ I²C-bus 100 mA 40 V LED driverPCA9624 - 8-bit Fm+ I²C-bus 100 mA 40 V LED driverPCA9626 - 24-bit Fm+ I²C-bus 100 mA 40 V LED driverPCA9632 - 4-bit Fm+ I²C-bus low power LED driverPCA9633 - 4-bit Fm+ I²C-bus LED driverPCA9634 - 8-bit Fm+ I²C-bus LED driverPCA9635 - 16-bit Fm+ I²C-bus LED driverPCA9685 - 16-channel, 12-bit PWM Fm+ I²C-bus LED controllerTemperature SensorsPCT2075 - Fm+ Temperature Sensor |
