查看: 339|回复: 0
W5200以太网的PICtail板
  • 签到天数: 361 天
    发表于 2014-2-18 11:19:08 | 显示全部楼层 |阅读模式
    W5200以太网的PICtail™板提供10/100 Mbps的半双工/全双工以太网通过板载WIZnet的W5200以太网控制器,它具有硬件TCP/ IP处理引擎的连接。它的工作原理与Explorer 16开发,PIC32 I / O扩展板,PICDEM.net2,PIC18 Explorer和其他进行运用。WIZnet`s W5200 Ethernet PICtail™ (Plus) board provides 10/100 Mbps, half/full duplex Ethernet connectivity by onboard WIZnet W5200 Ethernet controller, which has a hardwired TCP/IP processing engine. It works with Explorer 16, PIC32 I/O Expansion Board, PICDEM.net 2, PIC18 Explorer and others.Includes fast SPI interface, 2K EEPROM with EUI-48™ Node Identity (MAC address) and RJ-45 connector. Also provides Auto-negotiation, Auto-MDI/MDIX, Power-Down Mode and Wake-on-LAN functionalities.The W5200 Ethernet PICtail board supports both Microchip`s software TCP/IP Stack and WIZnet`s hardwired TCP/IP Stack on PIC18, PIC24, dsPIC and PIC32 platforms. The hardwired stack allows simple Internet connectivity for PICs with limited memory size such as PIC16 MCUs. For more information,
    TWIZ5200_Web.pdf
    121.31 KB, 下载次数: 1
    GMT+8, 2024-11-26 01:30 , Processed in 0.129503 second(s), 16 queries , MemCache On.
