SOIC14评估板是一个空白PCB ,它允许用户以配置电路的具体要求。有一个VDD焊盘和VSS的焊盘。这些垫可安装连接的帖子,让方便地连接到电源(VDD)和接地(VSS )的飞机。The 14-Pin SOIC/DIP/TSSOP Evaluation Board is a blank PCB that allows the user to configure the circuit to the exact requirements. The passive components use the surface-mount 805 package layout.The 14-Pin SOIC/DIP/TSSOP Evaluation Board has a VDD pad and a VSS pad. These pads can have connection posts installed that allow easy connection to the power (VDD) and ground (VSS) planes. The layout allows either through-hole or surface-mount connectors.
