查看: 265|回复: 0
AC243006-1 - 并行的SuperFlash套件
  • 签到天数: 361 天
    发表于 2014-2-17 15:13:35 | 显示全部楼层 |阅读模式
    AC243006-1 - 并行的SuperFlash套件,包含两个并行闪存的PICtail™Plus子板。该对话框包含两个并行闪存的PICtail™Plus子板。每块板都有焊接就可以了并行闪存器件。包括并行闪存器件SST38VF6401和SST39VF1601C。The Parallel Flash PICtail ™ Plus Daughter Board is an evaluation board designed to interface with the PICtail ™ Plus connector found on the Explorer 16 Development Board. The Parallel SuperFlash ® Kit 1 contains two Parallel Flash PICtail ™ Plus Daughter Boards. The box contains two Parallel Flash PICtail ™ Plus Daughter Boards. Each board has a parallel Flash device soldered on it. The parallel Flash devices included are SST38VF6401 and SST39VF1601C.
    GMT+8, 2025-1-16 05:51 , Processed in 0.106527 second(s), 15 queries , MemCache On.
