查看: 297|回复: 0
IPLogika评估套件(TIPL400)
  • 签到天数: 361 天
    发表于 2014-2-17 14:51:49 | 显示全部楼层 |阅读模式
    IPLogika评估套件(TIPL400)包括本机还有一个转接板和RS-232接口。它允许使用一个TCP/ IP协议栈,无牌,支持HTTP,TFTP,DHCP,插座级的UDP和TCP。支持用很少的努力完整的TCP/ IP访问,节省了开发成本。The Serial Gateway to Ethernet by IPLogika provides an easy Ethernet connection using simple UART communications. It allows the use of a TCP/IP stack, without licenses, supporting HTTP, TFTP, DHCP, socket-level UDP and TCP. Supports full TCP/IP access with very little effort, saving development costs.The Serial Gateway connects to a host system through two rows of header pins (0.1 inch spacing) that carry standard UART signals. It communicates with the host using high level AT commands. Includes web server mode that allows remote control of embedded applications with the capability to write and/or read up to 29 variables. Also supports SMTP protocol for sending emails with text file attachments. The RJ45 connector on board is EMI protected with LED indicator. 5VDC tolerant, small size. Note: The IPLogika Evaluation Kit (TIPL400) includes this unit along with a breakout board and RS-232 interface.
    GMT+8, 2025-1-16 05:41 , Processed in 0.111091 second(s), 15 queries , MemCache On.
