查看: 220|回复: 0
TC110升压转换器演示板
  • 签到天数: 361 天
    发表于 2014-2-17 14:23:59 | 显示全部楼层 |阅读模式
    TC110升压转换器演示板,可充电锂离子电池在最大500毫安恒流单节碱性电池或2节碱性电池。该TC110升压转换器演示板用于评估Microchip的TC110 PFM/ PWM升压型DC / DC控制器。The TC110 Boost Converter Demo Board can charge Li-Ion Batteries with single-cell Alkaline battery or 2-cell Alkaline battery at maximum 500 mA constant current. The TC110 Boost Converter Demo Board is used to evaluate Microchip’s TC110 PFM/PWM Step-Up DC/DC Controller.The TC110 is a step-up (Boost) switching controller that can regulate output voltage with a typical start-up voltage of 0.9V. The TC110 Boost Converter Demo Board also includes a MCP73832 Miniature Single-Cell, Fully Integrated Li-Ion, Li-Polymer Charge Management Controllers. Microchip’s MCP73832 is a highly advanced linear charge management controllers for use in space-limited, cost-sensitive applications.The TC110 Boost Converter Demo Board is a ready to use solution for portable applications when no DC plug is available. The TC110 Boost Converter Demo Board can efficiently transfer energy from Alkaline batteries to Li-Ion battery pack.
    TC110 Demo Board Guide.pdf
    222.69 KB, 下载次数: 0
    GMT+8, 2025-1-16 05:42 , Processed in 0.109360 second(s), 16 queries , MemCache On.
