查看: 362|回复: 0
打印 上一主题 下一主题
MCP2150开发板
  • 签到天数: 361 天
    跳转到指定楼层
    楼主
    发表于 2014-2-17 14:15:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    MCP2150开发板能够进行简单的演示红外线的应用和发展。该板可通过USB或电源测试点(VDD和GND)供电。The MCP2150 Developer’s Board allows for the easy demonstration and development of IrDA applications. The board can be powered via USB or the power test points (VDD and GND).The Host interface can be connected to the UART driver device for communication over the DB-9 connector (for IrDA to UART operation), connected to the PIC18F65J50 for stand alone operation, or connected to the PIC18F65J50 with the PIC18F65J50 connected to the UART driver device (for pass-through operation).
    MCP2150 Dev Board User's Guide.pdf
    1.51 MB, 下载次数: 0
    举报
    站长推荐上一条 2/5 下一条
    「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
    查看 »
    GMT+8, 2025-4-30 09:14 , Processed in 0.110156 second(s), 18 queries , MemCache On.
