TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
RS232网关以太网提供了RS-232通信更加便捷的以太网连接。它允许使用一个TCP/ IP协议栈,无需授权,支持HTTP,TFTP,DHCP,插座级的UDP和TCP。支持用很少的努力完整的TCP/ IP访问,节省了开发成本。The RS232 Gateway to Ethernet provides an easy Ethernet connection using RS-232 communications. It allows the use of a TCP/IP stack, without licensees, supporting HTTP, TFTP, DHCP, socket-level UDP and TCP. Supports full TCP/IP access with very little effort, saving development costs.Integrates with a host system though high level AT commands, and offers a web server with up to 29 variables, Dedicated Port Mode, transparent communication by serial channel as Server and Client Mode. Includes capability to send unlimited emails with attached text files. The RJ45 connector on board is EMI protected with LED indicator. Fully equipped with AC/DC power supply and RS-232 cable. |
