TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
IPLogika评估套件包含了串行网关到以太网(TIPL401)和分线板带RS-232接口。它演示了如何在串行网关连接到主机系统,并提供了使用简单的RS-232通信一件容易的以太网连接。The IPLogika Evaluation Kit includes the Serial Gateway to Ethernet (TIPL401) and a breakout board with RS-232 interface. It demonstrates how the Serial Gateway connects to a host system, and provides an easy Ethernet connection using simple RS-232 communications.The Serial Gateway allows the use of a TCP/IP stack, without licensees, supporting HTTP, TFTP, DHCP, socket-level UDP and TCP. The breakout board includes test points, LEDs, and buttons in addition to an RS-232 interface. It is ready to connect to Hyperterminal on a PC to test all the features that the Serial Gateway provides. This kit can also be used to evaluate the RS-232 Gateway to Ethernet (TIPL402) which connects to a host system via RS-232 interface. |
