查看: 347|回复: 0
打印 上一主题 下一主题
AC164142评估板
  • 签到天数: 361 天
    跳转到指定楼层
    楼主
    发表于 2014-2-17 11:01:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    The Consumer-band BPSK 7.2 kbps PLM PICtail Plus Daughter Board incorporates Analog Front End (AFE) circuitry, which is required to implement a software-based modem, using the dsPIC33F Digital Signal Controller (DSC) device on the Explorer 16 Development Board. The daughter board fits into the expansion slot on the Explorer 16 Development Board. A HV adapter cable (included in the package) interfaces the daughter board to the power line. The HV adapter cable incorporates the circuitry required to provide noise-filtering and isolation from the power line. The daughter board and the HV adapter cable are designed to operate at a carrier frequency of 129.6 kHz (CENELEC-C band).
    AC164142 User Guide.pdf
    1.3 MB, 下载次数: 0
    举报
    站长推荐上一条 2/5 下一条
    「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
    查看 »
    GMT+8, 2025-4-30 09:14 , Processed in 0.110746 second(s), 18 queries , MemCache On.
