查看: 525|回复: 0
ADS8364演示板
  • 签到天数: 361 天
    发表于 2014-1-9 16:05:52 | 显示全部楼层 |阅读模式
    ADS8364演示板是为ADS8364模拟 - 数字转换器(ADC)的原型进行设计和评估。The ADS8364M-EVM is designed for the prototyping and evaluation of the ADS8364 analog-to-digital converter (ADC). This high-resolution 16 bit, parallel analog-to-digital high-speed 250 kHz, SAR device, has a single or fully differential, pseudo-bipolar input. The EVM uses a INA159 amplifier (selected for its low noise), configured to allow the ADS8364 to operate at optimized performance to meet data sheet specifications.特性
    • Full-featured evaluation board for the ADS8364, 250 kHz, 16 bit, 6 channel, simultaneous-sampling, analog-to-digital converter
    • Analog inputs can be configured as single-ended or differential
    • Modular design allows direct connection to various DSP platforms through the 5-6K and HPA-MCU interface boards
    • The ADS8364M-EVM can use its internal reference by using jumper W3 on the board
    • Onboard input and output digital buffer connectors are available on the EVM
    ADS8364_65M EVM User's Guide.pdf
    275.67 KB, 下载次数: 0
    GMT+8, 2024-11-26 02:43 , Processed in 0.112201 second(s), 16 queries , MemCache On.
