查看: 222|回复: 0
LIS331DLH演示板
  • 签到天数: 361 天
    发表于 2014-1-9 14:15:23 | 显示全部楼层 |阅读模式
    LIS331DLH演示板是以芯片LIS331DLH为基础,能够为用户提供一个完整的设计。The STEVAL-MKI022V1 is a demonstration kit designed to provide the user with a complete, ready-to-use platform for demonstration of the LIS331DLH. The LIS331DLH is a low-power 3-axis linear accelerometer with digital output. The device includes a sensing element and an IC interface capable of translating information from the sensing element into a measured signal that can be used for external applications.In addition to the MEMS sensor, the demonstration board utilizes an ST7-USB microcontroller which functions as a bridge between the sensor and the PC, on which it is possible to use the graphical user interface downloadable to the website or dedicated software routines for customized applications.This user manual describes the hardware included with the demonstration kit and provides the information required to install and run the demonstration kit user interface.For details regarding the features of the LIS331DLH sensor, please refer to the datasheet for this device and application note AN2847.
    数据表.pdf
    680.11 KB, 下载次数: 1
    STEVAL-MKI022V1.pdf
    113.54 KB, 下载次数: 1
    LIS331DLH disclaimer_errata.pdf
    157.17 KB, 下载次数: 1
    GMT+8, 2024-11-26 02:56 , Processed in 0.116445 second(s), 16 queries , MemCache On.
