查看: 358|回复: 0
TDA7491LP D类音频放大器
  • 签到天数: 361 天
    发表于 2014-1-9 13:17:59 | 显示全部楼层 |阅读模式
    TDA7491LP评估套件评价tda7491lp双BTL D类音频功率放大器,并且它的效率高在没有任何散热片条件下也具有散热功能。The STEVAL-CCA029V1 demonstration board is designed for the evaluation of the TDA7491LP dual BTL class-D audio amplifier.Due to its high efficiency, the device, assembled in the PSSO36 (slug-down) package, is capable of dissipating heat without any heatsink. Jumpers on the board allow the configuration of the amplifier in order to verify all the features as single-ended or differential inputs, fixed gain settings. Microswitches are also provided to enable the standby and mute functions.Key Features
    • 5 W + 5 W continuous output power at THD = 10%, RL = 8 Ω, VCC = 9 V
    • 5 W + 5 W continuous output power at THD = 10%, RL = 4 Ω, VCC = 6.5 V
    • Power supply voltage range: 5 V to 14 V
    • Number of channels: 2 BTL (bridge tied load) stereo
    • Load impedance: 4 Ω to 8 Ω
    • Gain settings: 20 dB, 26 dB, 30 dB, 32 dB
    • Undervoltage protection (UVP): 4 V
    • External synchronization
    • RoHS compliant
    STEVAL-CCA029V1数据手册.pdf
    328.49 KB, 下载次数: 0
    GMT+8, 2024-11-26 02:36 , Processed in 0.115405 second(s), 16 queries , MemCache On.
