查看: 251|回复: 0
SI1120评估套件
  • 签到天数: 361 天
    发表于 2014-1-8 17:00:58 | 显示全部楼层 |阅读模式
    SI1120评估套件是Si1120环境光线传感器也是一种先进的评估平台。The Si1120 Evaluation Kit is an advanced evaluation platform for the Si1120 infrared proximity and ambient light sensor. Controlled by an advanced C8051F930 ultra low-power MCU, the Si1120EK contains an Si1120 sensor connected to three IR-LEDs. The three IR-LED configuration allows for advanced 3D/3-axis touchless gesture detection as well as general-purpose object proximity detection. In addition, the Si1120 sensor on the Si1120EK contains an integrated ambient light sensor.For real-time reflectivity monitoring with the IRMFB-EK, the Optical Sensor Software Tools contain Silicon Labs’ powerful Control Panel and Performance Analysis Tool for real-time reflectivity monitoring with the Si1120EK.The evaluation kit includes:
    • Si1120AB demonstration board
    • C8051F930-TB1120
    • Power adapter
    • USB debug adapter
    • USB cables
    Si1120EK-qs-guide.pdf
    228.73 KB, 下载次数: 0
    optical-sensors-solutions-guide.pdf
    871.91 KB, 下载次数: 0
    GMT+8, 2024-11-26 02:26 , Processed in 0.118820 second(s), 16 queries , MemCache On.
