查看: 303|回复: 0
RL78G13嵌入式MCU开发板
  • 签到天数: 361 天
    发表于 2014-1-8 16:38:33 | 显示全部楼层 |阅读模式
    RL78/G13开发套件接上PC后可以简单的演示A/D转换器,RTC。内存读写,低功耗模式,硬件自检动作。RL78/G13 Group microcontrollers employ the RL78 core which realizes high processing performance while delivering the lowest power consumption in their class.A high-precision (±1%) on-chip oscillator makes 32 MHz CPU operation possible, and built-in features such as a reset circuit, a low voltage detection circuit, a watchdog timer, and data flash with background operation function help to lower the total cost of building a system and contribute to more compact size and lower power consumption.In addition, abundant functions for supporting functional safety, such as an A/D converter testing function, are also on-chip.With a broad product lineup covering 16 KB to 512 KB of flash memory and 20 to 128-pin packages, these products are suitable for home appliances, mobile devices, healthcare devices, and other consumer electronics, office equipment, industrial equipment, and so on.关键特性Operating voltage: VDD = 1.6 to 5.5 VMax. frequency: 32 MHzROM capacities: 16 KB to 512 KB flash memoryRAM capacities: 2 KB to 32 KBAvailable on-chip data flash (4 to 8 KB) products (Product name :R5F1006x, R5F1007x, R5F1008x, R5F100Ax, R5F100Bx, R5F100Cx, R5F100Ex, R5F100Fx, R5F100Gx R5F100Jx, R5F100Lx, R5F100Mx, R5F100Px, R5F100Sx)Variable pin count (20 to 128 pins) and packages are available.Minimum instruction execution time can be changed from high speed (0.03125 µs: @ 32 MHz operation with highspeed system clock) to ultra low-speed (30.5 µs: @ 32.768 kHz operation with subsystem clock)General-purpose register: 8 bits x 32 registers (8 bits x 8 registers x 4 banks)On-chip internal high-speed oscillation clock
    • 32 MHz internal high-speed s oscillation clock: 32 MHz (TYP.)
    On-chip single-power-supply flash memory (with prohibition of chip erase/block erase/writing function)Self-programming (with boot swap function/flash shield window function)On-chip debug functionOn-chip power-on-reset (POR) circuit and voltage detector (LVD)On-chip watchdog timer (operable with the on-chip internal low-speed oscillation clock)On-chip multiplier/divider/multiply-accumulator
    • 16 bits x 16 bits = 32 bits(signed)
    • 32 bits / 32 bits = 32 bits(unsigned)
    • 16 bitsx 16 bits + 32 bits = 32 bits (signed)
    • 16 bitsx 16 bits + 32 bits = 32 bits (unsigned)
    On-chip key interrupt functionOn-chip clock output/buzzer output controllerOn-chip BCD adjustmentI/O ports: 16 to 120 (N-ch open drain: 0 to 4)Timer
    • 16-bit timer: 8 to 16 channels
    • Watchdog timer: 1 channel
    • Realtime counter: 1 channel
    • Interval timer: 1 channel
    Serial interface
    • CSI
    • UART (LIN-bus supported)
    • I2C/simplified I2C
    Stanby function
    • HALT
    • STOP
    • SNOOZE
    8/10-bit resolution A/D converter(VDD = EVDD = 1.6 - 5.5 V): 6 to 26 channelsOperating ambient temperature: TA = -40 to +85°C关键应用
    • Consumer Electronics, Industrial
    RL78_G13开发套件快速入门教材.pdf
    2.58 MB, 下载次数: 1
    GMT+8, 2024-11-26 02:26 , Processed in 0.122039 second(s), 16 queries , MemCache On.
