TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
RX111入门套件是作为为用户更好的介绍和评价rx111单片机的工具。Product OverviewThe Renesas Starter Kit for RX111 is intended as a user-friendly introductory and evaluation tool for the RX111 microcontroller. The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using CubeSuite+.Renesas Starter Kit for RX111 may be connected to the host PC using the included USB E1 on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.* CubeSuite+ is not generally promoted to the U.S. and European customers. Customers in the U.S. and Europe who are interested in CubeSuite+ are requested to contact our regional marketing departments for details.Product LimitationA limitation exists with the board used on a batch of Renesas Starter Kit for RX111 Products.Serial Numbers Affected: 00045380 to 00045879 inclusive.Limitation:
- The RSKRX111 board 3.3V supply is actual at 3.8V.
Explanation:
- By mistaken voltage regulator mounting, regulator does not provide 3.3V.
Work-around:
- Please modify the RSKRX111 board as follows.
- This modification will provide 3.3V.
- Remove R103 and replace R104 with 0R resistor.
- Link J7 should be left open.
Configuration[Kit with Renesas CubeSuite+]
- CPU Board
- Monochrome LCD Board PmodTM Compatible
- Detachable AD Adjustment Shaft
- E1 Emulator
- Connection Cable (USB Cable, User Interface Cable)
- Quick Start Guide
- DVD-ROM
- Documents: User Manual, Tutorial, and more- IDE: CubeSuite+ (Evaluation Software)C/C++ Compiler Package for RX Family Evaluation VersionE1 Emulator Debugger- Flash Memory Programmer:Renesas Flash Programmer (Evaluation Software) |
