查看: 339|回复: 0
SMARTFUSION2入门套件
  • 签到天数: 361 天
    发表于 2014-1-8 10:52:48 | 显示全部楼层 |阅读模式
    SMARTFUSION2入门套件包含有smartfusion2系统芯片(SOC)的FPGA方便了设计师的访问。Microsemi's SmartFusion2 Starter Kit provides designers with access to SmartFusion2 system-on-chip(SoC) FPGAs, which integrate inherently reliable flash-based FPGA fabric, a 166 MHz ARM Cortex-M3 processor, advanced security processing accelerators, DSP blocks, SRAM, eNVM and industry required high-performance communication interfaces all on a single chip.The SmartFusion2 starter kit supports industry-standard interfaces including Ethernet, USB, SPI, I2C and UART and includes a comprehensive breadboard to support unique design requirements. The kit can be used with Microsemi's Libero SoC v11.0 software, which includes a free Libero Gold license and comes preloaded with a uClinux demo. Emcraft Systems' Linux-based development environment is also supported. The SmartFusion2 device is available on an Emcraft Systems miniature (34mm x 59mm) mezzanine form factor system-on-module (M2S-SOM), which connects to the SOM-BSB-EXT baseboard. The kit is USB powered and includes FlashPro4 programming.Hardware Feature Overview
    • SmartFusion2 SoC FPGA in the FG896 package (M2S050T-FG896ES)
    • JTAG interface, for programming of the SmartFusion2 device
    • 10/100 Ethernet interface and RJ-45 connector
    • USB OTG interface and mini-USB connector
    • USB based Wi-Fi Module
    • 64MB LPDDR, 16MB SPI flash
    • User push-button connected to GPIO on the SOM
    • Two user-controlled LEDs connected to GPIO on the SOM
    • Breadboard area available for GPIO or FPGA I/O connection
    • Power good LED indicating presence of the +3.3 V SOM power
    • Reset push button, Reset-out LED
    • On-module clocks
    • Watchdog Timer (WDT)
    • Serial console interface at UART CMOS levels
    • Low power mode with fast wake-up times
    • Depending on the design, can provide necessary power supply voltages (+5 V, +3.3 V, +1.5 V for power-optimized SOM operation) from external sources through dedicated pads on the breadboard.
    SmartFusion2 DSP FIR Filter Demo User Guide.pdf
    2.64 MB, 下载次数: 0
    SmartFusion2 SoC FPGA Adaptive FIR Filter Demo User’s Guide.pdf
    3.79 MB, 下载次数: 0
    SOM-BSB-EXT Baseboard Hardware Architecture Specification.pdf
    118.8 KB, 下载次数: 0
    GMT+8, 2024-11-26 03:32 , Processed in 0.122498 second(s), 16 queries , MemCache On.
