查看: 362|回复: 0
IGLOO PLUS评估套件
  • 签到天数: 361 天
    发表于 2014-1-8 10:33:27 | 显示全部楼层 |阅读模式
    IGLOO PLUS评估套件提供了一种低成本的系统评价平台。使初学者能够迅速评估雪屋+技术(aglp),且该套件完全符合RoHS标准。Microsemi's IGLOOTM PLUS Starter Kit provides a low-cost system evaluation platform with Microsemi's AGLP125V2 IGLOO PLUS device in the CSG289 package. The Starter Kit is fully RoHS compliant and enables you to swiftly evaluate IGLOO PLUS technology (AGLP), such as low power, I/O state preservation during Flash*Freeze mode, Schmitt triggered I/Os and use of Schmitt triggered FPGA inputs for improved noise immunity. The evaluation board also enables you to measure power consumption (dynamic, static and Flash*Freeze mode) with the core operating at either 1.2 V or 1.5 V.Since the CSG289 package uses a common footprint across the complete IGLOO PLUS family-AGLP030, AGLP060 and AGLP125 devices-you can use the IGLOO PLUS Starter Kit for applications targeted for any IGLOO PLUS device.Evaluation board with an IGLOO PLUS AGLP125V2-CSG289 device
    • Full current measurement capability of independent I/O banks and VCC for accurate power analysis
    • Two I/O banks held at 3.3 V, two I/O banks may be independently set to 3.3 V, 2.5 V, or to the sweep voltage of 1.2 V to 1.5 V (potentiometer set)
    • Low power precision 20 MHz oscillator for system clock is provided
    • Three LEDs and three switches provide simple inputs and outputs to the system
    • USB-to-UART connection for HyperTerminal on a PC
    • Optional board power connector for an external supply, but none is needed when connected to a USB cable
    • Ability to switch VCORE from 1.2 V to 1.5 V as needed and vary the core to simulate battery failure
    • JTAG pins may be run at any voltage from 1.2 V to 1.5 V
    • Most I/O intensive, lowest power 125,000 system-gate FPGA
    ---Dynamic, Static and Flash*Freeze power consumption are phenomenally low on the AGLP125V2.
    ---IGLOO PLUS offers the industry's best ratios of power, area, logic and features per I/O in a programmable device, delivering 6X better static power consumption, a 50% reduction in dynamic power consumption, a 2X improvement in I/O density, and as much as 2.7X the logic density compared with competitive programmable logic devices in a similar package.
    • Eight test LEDs
    • Four test switches and a reset switch
    • All I/Os available for quick connection to external circuitry
    EU_Declaration_of_Conformity.pdf
    115.95 KB, 下载次数: 0
    SOC-ProductCatalog-Sept13-FINAL_LR.pdf
    2.08 MB, 下载次数: 0
    GMT+8, 2024-11-26 03:51 , Processed in 0.118745 second(s), 16 queries , MemCache On.
