查看: 562|回复: 0
打印 上一主题 下一主题
PIC32 以太网入门套件
  • 签到天数: 361 天
    跳转到指定楼层
    楼主
    发表于 2014-1-7 16:47:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    PIC32 以太网入门套件提供了简单和低成本的方法对PIC32的10 / 100以太网的发展。The PIC32 Ethernet Starter Kit provides the easiest and lowest cost method to experience 10/100 Ethernet development with PIC32. Combined with Microchip's free TCP/IP software, your project will be running in no time. The PIC32 has an available CAN 2.0b peripheral and USB host/device/OTG.The Ethernet Starter Kit has a form factor and expansion connector that are compatible with other PIC32 Starter Kits.write code
    • Free MPLAB IDE v8.43 or newer
    • Free MPLAB C Compiler for PIC32 with no code size limit
    • Example project files for Ethernet and USB applications
    program memory
    • Integrated programmer - all you need is the included USB Cable
    • Program and verify a full 512k image in less than 9 seconds
    debug
    • Integrated debugger - all you need is the included USB cable
    • Full C source-based debugging in MPLAB IDE
    execute code
    • PIC32 running at 80 MHz with 512K Flash, 128K RAM, 8 ch. DMA + 8 ch. DMA dedicated to Ethernet,          CAN and USB
    • USB powered board
    • USB and Ethernet connectors, user switches, and LEDs
    customize
    • Expansion connector enables addition of Microchip's PIC32 expansion boards or create your own
    • Majority of MCU signals are present on the connector [Hirose: FX10A-120P/12-SV1(71)]
    Box Contents:
    • PIC32 Ethernet Starter Board
    • Standard A to mini B cable for debugger
    • Standard A to micro B cable for USB application development
    • Ethernet cable
    The PIC32 Ethernet Starter Kit runs on Microsoft Windows 2000, Windows XP, Windows Vista, and Windows 7.
    PIC32 Ethernet Starter Kit User_s Guide .pdf
    1.38 MB, 下载次数: 0
    PIC32 Ethernet Starter Kit Information Sheet .pdf
    99.17 KB, 下载次数: 0
    举报
    站长推荐上一条 1/4 下一条
    有奖活动|英飞凌智能座舱直播活动
    查看 »
    GMT+8, 2025-4-15 17:13 , Processed in 0.114238 second(s), 18 queries , MemCache On.
