查看: 263|回复: 0
ISL28617评估板
  • 签到天数: 361 天
    发表于 2014-1-6 13:43:10 | 显示全部楼层 |阅读模式
    ISL28617评估板是评估isl28617仪表放大器(AMP)的大块金属®箔电阻。The ISL28617VYXXEV1Z评估板来评估ISL28617仪表放大器与威世精密集团 Bulk Metal® Foil电阻器的性能。它的差分输入电压范围高达±34V,电源电压范围是8V(±4V)至40V(±20V)并且增益范围从0.1到10000,这在精密仪表放大器具有广泛的应用。它具有差分输入和输出,并能驱动轨至轨的输出。KEY FEATURES
    • Rail-to-rail Differential Output ADC Driver
    • High Voltage Interface to Low Voltage Circuits
    • Wide Operating Voltage Range: ±4V to ±20V
    • Low Input Offset: 30μV
    • Excellent CMRR and PSRR: 120dB
    • Closed Loop -3dB BW: 0.3MHz (AV = 1k) to 5MHz (AV = 0.1)
    • Operating Temperature Range: -40°C to +125°C
    APPLICATIONS
    • Precision Test and Measurement
    • High Voltage Industrial Process Control
    • Signal Conditioning Amplifier for Remote
    • Powered Sensors
    • Weigh Scales
    • ECG and Biomedical Sense Amplifiers
    ISL28617 数据手册.pdf
    970.39 KB, 下载次数: 0
    ISL28617VYXXEV1Z User’s Guide.pdf
    222.18 KB, 下载次数: 0
    GMT+8, 2025-1-16 08:46 , Processed in 0.121942 second(s), 16 queries , MemCache On.
