查看: 327|回复: 0
PSoC5基于Cortex-M3 内核开发套件
  • 签到天数: 361 天
    发表于 2014-1-3 11:16:47 | 显示全部楼层 |阅读模式
    PSoC5开发套件使您能够评估,开发原型的高精度模拟,低功耗和低电压应用的高精度模拟等。CY8CKIT-050 PSoC 5LP 开发套件让您可以评估、开发和原型设计高精度模拟、低功耗、低电压应用。 Cypress CY8C58LP 提供微控制器、存储器、模拟和数字功能,用于信号采集、处理和控制,具有高精度和高带宽。PSoC 5LP 开发套件设计用于模拟性能,具有低噪声水平。 它还可演示 PSoC 5LP 32位 ARM Cortex-M3 可编程片上系统的低功耗操作。The CY8CKIT-050 PSoC® 5LP Development Kit enables you to evaluate, develop and prototype high precision analog, low-power and low-voltage applications powered by Cypress’s CY8C58LP high precision analog device family.Additionally, this kit supports the PSoC Expansion Board Kit ecosystem as a compatible host platform. This kit is designed specifically for PSoC 5LP development, the PSoC 3 version of the same kit can be purchased from www.cypress.com/go/cy8ckit-030.This kit is designed for analog performance. The kit features a very low noise floor. Care has been taken to separate the analog and the digital domain. Separate regulators are also available and separate ground planes are provided. We have achieved ENOB very close to 20 bits with this kit. Provisions are provided to add an external precision voltage reference, if needed.Besides the analog, this kit is also meant to demonstrate the low power operation of PSoC 5LP. The PSoC 5LP chip is soldered to the board, this significantly reduces the leakage currents compared to the CY8CKIT-001. Special terminals are provided to enable the boost converter operation without requiring many modifications. Jumpers have been provided to remove power to RS232 converter, potentiometer, to have a single regulator for analog and digital domain, and evaluate the low power operation of PSoC 5LP.The Kit-050 has an onboard programmer/debugger (Cypress USB chip based), which lets you program the PSoC 5 without connecting Miniprog3. This programmer debugs at a speed of 1.5mHz. The kit also allows the user to program and debug using the Miniprog3.Kit Contents:
    • PSoC 5LP Development Board
    • LCD Character Display
    • USB Cable
    • Quick Start Guide
    • Kit CD, which includes: PSoC Creator, PSoC Programmer, Projects and Documentation
    CY8CKIT-050_Kit_Guide_001-65816.pdf
    9.78 MB, 下载次数: 0
    CY8CKIT-050_Quick_Start_Guide_001-65815.pdf
    1.66 MB, 下载次数: 0
    CY8CKIT-050_Release_Notes_001-66176.pdf
    121.21 KB, 下载次数: 0
    GMT+8, 2025-1-16 09:05 , Processed in 0.113732 second(s), 16 queries , MemCache On.
