查看: 295|回复: 0
PowerPSOC照明套件
  • 签到天数: 361 天
    发表于 2014-1-2 17:09:27 | 显示全部楼层 |阅读模式
    PowerPSOC照明套件使设计人员能够评估PowerPSoC家庭设备,同时论证其创建可扩展的LED管理解决方案的能力。The CY3267 PowerPSoC™ Lighting Evaluation Kit enables designers to evaluate Cypress' PowerPSoC family of devices and demonstrates their ability to create scalable LED management solutions. The PowerPSoC devices feature high performance power electronics including 1A, 2 MHz power FETs, hysteretic controllers, current sense amplifiers, and PrISM™ modulators to create a complete solution for LED power management. Right out of the box, the CY3267 Kit can be used to evaluate PowerPSoC's ability to drive 4 LED channels (Red, Green, Blue and Amber) at the desired color and brightness output.Kit Contents
    • The CY3267 PowerPSoC Lighting Evaluation Kit contains:
    • CY3267 PowerPSoC main board
    • CY3267 LED daughter board
    • 12 V, 2 A power supply
    • Optical diffuser
    • Retractable USB cable
    • CY3217-MiniProg1 Programmer
    • 5 PowerPSoC CY8CLED04D01-56LTXI samples
    • Quick Start Guide
    • Kit CD which includes
    ---PSoC Designer
    ---PSoC Programmer
    ---Intelligent Lighting Control GUI
    ---Demo firmware
    ---Design files
    ---Related documents
    Featuring:
    • Out-of-box evaluation experience using the PowerPSoC Main Board, RGBA LED daughter card and Intelligent Lighting Control GUI, all included in the kit
    • Kit default firmware demonstrates HB-LED control with intelligent color mixing using PowerPSoC
    • Interface to custom LED daughter boards through screw terminals from the PowerPSoC mother board
    • Flexible input voltage options (7 V to 32 V)
    • Debug capability provided by the PowerPSoC On Chip Debugger (OCD) device and RJ-45 jack that connects to CY3215DK ICE Cube Emulation Kit (sold separately)
    • PC USB connectivity through on-board USB controller
    • CY3271 FirstTouch RF Kit* Connector
    • CyFi Radio Module* Connector
    • Access to all Function I/O pins of PowerPSoC for additional design and debug capability
    CY3267 - Evaluation Kit Guide_001-49266.pdf
    2.87 MB, 下载次数: 0
    CY3267 - Release Notes_001-67387.pdf
    134.59 KB, 下载次数: 0
    CY3267 - Quick Start Guide.pdf
    1.01 MB, 下载次数: 0
    GMT+8, 2025-1-16 09:01 , Processed in 0.114251 second(s), 16 queries , MemCache On.
