查看: 445|回复: 0
ATSAM4S评估套件
  • 签到天数: 361 天
    发表于 2014-1-2 15:54:19 | 显示全部楼层 |阅读模式
    This kit lets designers quickly evaluate and develop code for applications running on Atmel® SAM4S with the ARM®-based Cortex®-M4 core.键特性
    • Atmel SAM4SD32C chip in LQFP100 package with optional socket footprint
    • 12 MHz crystal
    • 32.768 KHz crystal
    • Optional SMB connector for external system clock input
    • NAND Flash
    • 2.8 inch TFT color LCD display with touch panel and backlight
    • UART port with level shifter circuit
    • USART port with level shifter circuit multiplexed with RS485 port with level shifter circuit
    • Microphone input and mono/stereo headphone jack output
    • SD/MMC interface
    • Reset button: NRST
    • User buttons: Left and Right
    • Atmel QTouch® buttons: Up, Down, Left, Right, Valid and Slider
    • Full-speed USB device port
    • JTAG/ICE port
    • On-board power regulation
    • BNC connector for ADC input
    • BNC connector for DAC output
    • User potentiometer connected to the ADC input
    • ZigBee® connector
    Building Automation
    • 舒适性与控制
    • 消防与安全
    Home Entertainment
    • 音频
    Industrial Automation
    • PLC 和 I/O 模块
    • 仪表
    Metering
    • 电表
    • 家庭显示装置
    Mobile Electronics
    • 笔记本电脑
    • 便携式音频播放器
    • 移动电话和移动互联网设备
    PC Peripherals
    • 音频 I/O 设备
    Atmel_11176_32-bit-Cortex-M4-Microcontroller-SAM4S-EK2_User-Guide.pdf
    843.65 KB, 下载次数: 0
    GMT+8, 2025-1-16 09:11 , Processed in 0.122839 second(s), 16 queries , MemCache On.
