查看: 224|回复: 0
SAMA5D33 评估套件
  • 签到天数: 361 天
    发表于 2014-1-2 15:24:34 | 显示全部楼层 |阅读模式
    The SAMA5D33-EK is a full-featured evaluation platform for the Atmel SAMA5D33embedded microprocessor. The kit consists of a main board, a computer module equipped with a SAMA5D33    processor, and a display module. It is supported by the SAMA5D3 Softpack, a free set of bare metal C examples, and is delivered with on-board demos for Linux and Qt-based GUI. The SAMA5D33-EK allows users to extensively evaluate, prototype and create applications that require graphics, audio, mass storage, networking, connectivity and more.Source files and binaries for the on-board demo are available on Linux4SAM, the entry point to open source solutions for Atmel ARM® core-based embedded microprocessors.关键特性
    • Atmel SAMA5D33 embedded MPU running at 536MHz in a BGA324 package
    • 4Gb DDR2, 2Gb NAND Flash, 128Mb NOR , 32Mb SPI Serial DataFlash, 512Kb EEPROM
    • JLink and CDC on-board, optional JTAG test access port
    • RGMII Ethernet 1Gb w/PHY
    • Four-wire RS232
    • Two USB 2.0 Hosts, one USB 2.0 Host/Device
    • Conexant CX20548 SmartDAA for soft modem implementation
    • MicroSD card slot
    • MMC/MMC+/SD/SDIO/CE-ATA
    • Headphone output, line in and microphone
    • One 5.0” WVGA resistive TFT LCD module with four QTouch keys
    • One ISI interface for connection to a CMOS sensor
    • One HDMI interface
    • One 10-pin connector for Atmel RZ600 ZigBee® module
    Atmel_11121S_32-bit-Cortex-A5-Microcontroller_SAMA5D3_Summary-Datasheet.pdf.pdf
    558.93 KB, 下载次数: 0
    Atmel_11180_32-bit-Cortex-A5-Microcontroller_SAMA5D3-Series-EK_User-Guide.pdf
    3.03 MB, 下载次数: 0
    GMT+8, 2025-1-16 08:50 , Processed in 0.122372 second(s), 16 queries , MemCache On.
