查看: 244|回复: 0
ADF4360-9评估板
  • 签到天数: 361 天
    发表于 2014-1-2 15:05:59 | 显示全部楼层 |阅读模式
    ADF4360-9评估板被设计为,允许用户评估集成的PLL和VCO的adf4360-9频率合成器。它包含一个USB连接器,adf4360-9bcpz,和RF输出的SMA连接器。The EV-ADF4360-9EB1Z board is designed to allow the user to evaluate the performance of the ADF4360-9 frequency synthesizer consisting of an integrated PLL and VCO (see Figure 1). It contains the ADF4360-9BCPZ, a USB connector, and SMA connectors for the RF outputs. Unpopulated SMA footprints are available for the power supplies, lock detect, and the external reference input. The evaluation board also contains the loop filter to complete the PLL. It can be modified as necessary for the user’s PLL requirements. A USB cable is included with the board to allow software programmability。ADF4360-9是一款集成电压控制振荡器(VCO)的整数N分频频率合成器,中心频率由外部电感设置,VCO频率范围为65 MHz至400 MHz。附加的分频器级可以对VCO信号进行分频。CMOS电平输出相当于经过2到31之间的整数值分频的VCO信号。如果需要,此分频信号可以进一步进行二分频处理。所有片内寄存器均通过简单的三线式接口进行控制。该器件采用3.0 V至3.6 V电源供电,不用时可以关断。应用
    • 系统时钟产生
    • 测试设备
    • 无线局域网(LAN)
    • 有线电视设备
    用户指南.pdf
    937.6 KB, 下载次数: 0
    Clock Generator PLL with Integrated VCO Data Sheet.pdf
    436.66 KB, 下载次数: 0
    GMT+8, 2025-1-16 08:46 , Processed in 0.114489 second(s), 16 queries , MemCache On.
