查看: 1295|回复: 0
AC243005-1工具包
  • 签到天数: 361 天
    发表于 2013-12-27 17:23:45 | 显示全部楼层 |阅读模式
    AC243005-1工具包的工具使设计人员能够评估串行闪存、快速开发和良好的利用已知硬件测试固件。OverviewThe Serial SuperFlash® Kit 1 allows evaluation of SST Serial Flash Devices which are made using the SST SuperFlash® technology. The Serial SuperFlash® Kit 1 contains three Serial Flash PICtail™ Plus Daughter Boards. The Serial Flash PICtail Plus Daughter Board is designed to interface with PICtail Plus connector found on Explorer 16 development board.Kit Contents
    • 3 Serial Flash PICtail™ Plus Daughter Boards
    • The following devices are mounted on the Serial Flash PICtail Plus Daughter Boards:
    SST25VF016BSST25VF064CSST26VF032 Features
    • 8-pin header provides easy access to Serial Flash pins for probing and evaluation
    • 3-pin header provides easy access for external power supply and power measurement capability
    • Plugs into PICtail™ Plus connector of Explorer 16 development board
    Required Development Tools
    •  Explorer 16 100 pin Development Board DM240001
    • PIC24FJ128GA010 Processor Installation Module (PIM) MA240011
    • MPLAB® X Integrated Development Environment (IDE)
    • 9 V Power Supply AC002014
    Serial Flash PICtail Plus Daughter Board Schematic .pdf
    39.91 KB, 下载次数: 0
    Serial SuperFlash® Kit 1 Infosheet .pdf
    96.04 KB, 下载次数: 0
    SST25VF016B Software Drivers and Example Codes .zip
    66.63 KB, 下载次数: 0
    SST25VF064C Software Drivers and Example Codes .zip
    75.93 KB, 下载次数: 0
    SST26VF032 Software Drivers and Example Codes .zip
    75.91 KB, 下载次数: 0
    GMT+8, 2025-1-16 11:11 , Processed in 0.104947 second(s), 16 queries , MemCache On.
