查看: 191|回复: 0
APGRD004 参考设计
  • 签到天数: 361 天
    发表于 2013-12-27 14:57:42 | 显示全部楼层 |阅读模式
    APGRD004 参考设计,设计了基于单片机控制的RGB LED器件。The Ambient Lighting Module Reference Design offers a compact solution to control a RGB (Red, Green, Blue) LED over a LIN network. A RGB LED module can be used for illumination, backlighting or indication in a vehicle.The Automotive Ambient Interior Lighting Module Reference Design demonstrates microcontroller-based control of RGB LED devices. This module can be controlled remotely by a master body controller via a LIN bus. These modules are offered in a very compact form-factor board and comprise of a PIC12F615 MCU, an MCP2021 LIN transceiver/voltage regulator, and RGB LED. LIN commands are interpreted by the module to control color mixing (16,383 colors) and intensity (1023 levels). The kit ships with 4 modules to assign as lighting zones in a LIN or J2602 network. These modules can also be used in conjunction with the APGDT001 LIN Serial Analyzer to quickly create a working LIN network straight out of the box.This reference design uses a low end 8-bit microcontroller to implement:
    • RGB LED color mixing (16,383 colors) and intensity (1023 levels)
    • A LIN Protocol module allowing for intersystem communication within the door module as well as the main body controller.
    The kit contains 4 modules, which can also be used in conjunction with the APGDT001 LIN Serial Analyzer to quickly create a working LIN network straight out of the box.
    Interior Ambient Lighting Module with LIN Interface User's Guide .pdf
    521.67 KB, 下载次数: 0
    GMT+8, 2025-1-16 11:03 , Processed in 0.102669 second(s), 16 queries , MemCache On.
