查看: 309|回复: 0
AC243004 演示板
  • 签到天数: 361 天
    发表于 2013-12-27 14:30:49 | 显示全部楼层 |阅读模式
    AC243004 演示板是用来说明一个标准的半波整流和电容器的电路,可用于寄生一个单/ O设备,从复杂的信号中提取应用笔记描述能力。The UNI/O Bus Parasitic Power Demo Board is designed to illustrate how a standard half-wave rectifier and capacitor circuit can be used to parasitically extract power for a UNI/O device from the SCIO signal as described in application note, AN1213 Powering a UNI/O Bus Device Through SCIO. This reduces the number of connections necessary for adding a UNI/O device to your application down to two: SCIO and Vss.The board is designed to interface with MPLAB Serial Memory Starter Kit, but the included test points allow you to interface the board with any application through the use of test leads (not included).
    GMT+8, 2025-1-16 11:12 , Processed in 0.116839 second(s), 15 queries , MemCache On.
