查看: 197|回复: 0
TDEVP001 触摸Web服务器组合套件
  • 签到天数: 361 天
    发表于 2013-12-27 13:24:39 | 显示全部楼层 |阅读模式
    TDEVP001 触摸Web服务器组合套件可以快速连接互联网支持远程控制和监测几个简单的步骤。安装方便、连接后,可以通过一个预编程的HTML页面访问板上的开关和发光二极管The Net-Touch Web Server Combo Kit from Devpeak enables quick Internet connectivity supporting remote control and monitoring in a few simple steps. Setup is easy and once connected you can access the switches and LEDs on the board via a preprogrammed HTML page. The USB port allows for easy changes such as setting IP address, gateway address/mask, enabling DHCP and IP Gleaning. This all-in-one kit includes LCD display, breakout board with prototype area, sturdy enclosure, USB cable, and power supply.
    • Based on PIC18F97J60 and Microchip`s TCP/IP firmware stack
    • Supports 8 digital outputs, 4 digital inputs, 1 analog input
    • Pre-programmed MCU for quick and easy startup
    • Compact, sturdy enclosure included
    GMT+8, 2025-1-16 11:04 , Processed in 0.107879 second(s), 15 queries , MemCache On.
