查看: 259|回复: 0
AC164127-8 演示板
  • 签到天数: 361 天
    发表于 2013-12-26 15:30:24 | 显示全部楼层 |阅读模式
    AC164127-8 演示板是评价芯片图形显示解决方案和图形库为16位和32位微控制器的一个演示板。The Graphics Display Truly 5.7 640x480 Board is a demonstration board for evaluating Microchips graphics-display solution and graphics library for 16 and 32-bit microcontrollers. This expansion board is compatible with LCD controller boards such as the Graphics Controller PICtail Plus Epson S1D13517 Board (AC164127-7).
    • TFT Display with 24-bit parallel RGB interface and 4-wire, resistive-touch interface
    • Resistive-touch controller (AR1020) interfaced to the MCU through the SPI module
    • Additional direct interface to MCU for 4-wire, resistive-touch signals
    Graphics Display Truly 5 640 x 480 Board Information Sheet .pdf
    145.21 KB, 下载次数: 0
    PIC32 WVGA VGA Epson S1D13517 Demo .zip
    3.89 MB, 下载次数: 0
    GMT+8, 2025-1-16 11:03 , Processed in 0.111548 second(s), 16 queries , MemCache On.
