查看: 283|回复: 0
AC164145接口板
  • 签到天数: 361 天
    发表于 2013-12-26 14:54:29 | 显示全部楼层 |阅读模式
    AC164145接口板提供了使用二进制相移键控的电力线通信(BPSK)调制方案。Overview The Power-Line Modem (PLM) PICtail™ Plus Daughter Board provides communication over power-lines using a Binary Phase Shift Keying (BPSK) modulation scheme. These boards interface to the popular Explorer 16 Development Board and operate in the CENELEC A utility frequency band at a carrier frequency of 72 kHz. The software modem runs on the dsPIC33F Digital Signal Controller (DSC) and utilizes an Analog Front End (AFE) to interface to the AC power mains. Each of the communication nodes utilizes a high voltage (HV) adapter cable that connects Utility-Band BPSK-Based 6 Kbps Power-Line Soft-Modem to the AC mains. The HV adapter cable incorporates the circuitry required to provide the noise-filtering and isolation from the power-line. Features Operates on 5V and 9V power supplyModulation and demodulation in softwareVariable transmit power level setting Compatible with 220V/50 Hz and 110V/60 Hz power-lines, or any AC line ranging from 0-220VAC at 50 or 60Hz Getting Started To get started, two Explorer 16 boards with dsPIC33FJ256GP710A devices and two 9V power supplies are required for point to point communication. The Power-Line Modem (PLM) PICtail Plus Daughter Boards allow insertion into the Explorer 16 development boards in only one orientation. The demonstration software provides all of the source code required to implement power-line communication. In addition, there are also five different demos with example source code. Two Utility-Band BPSK-based 6 Kbps Power-Line Soft-Modems are included in this kit. Explorer 16 boards can be purchased separately. Package ContentsInfo Sheet(2) Utility-Band BPSK-based 6 Kbps Power-Line Soft-Modem PICtail Plus Daughter Boards(2) High Voltage Adapter Cables
    Utility-band BPSK 6.0 kbps PLM PICtail Plus Daughter Board User's Guide .pdf
    1.14 MB, 下载次数: 0
    Utility-band BPSK-based 6kbps Powerline Softmodem PICtail Plus Ping Pong Demo .zip
    298.65 KB, 下载次数: 0
    Utility-band BPSK-based 6kbps Powerline Softmodem PICtail Plus Pipe Demo .zip
    281.35 KB, 下载次数: 0
    Utility-band BPSK-based 6kbps Powerline Softmodem PICtail Plus Sensor Demo .zip
    298.22 KB, 下载次数: 0
    Utility-band BPSK-based 6kbps Powerline Softmodem PICtail Plus Stream Demo .zip
    314.82 KB, 下载次数: 0
    Utility-band BPSK-based 6kbps Powerline Softmodem PICtail Plus Talk Demo .zip
    283.2 KB, 下载次数: 0
    Utility-band BPSK-based 6kbps Powerline Softmodem PICtail Plus Template .zip
    279.53 KB, 下载次数: 0
    GMT+8, 2025-1-16 10:53 , Processed in 0.124590 second(s), 16 queries , MemCache On.
