查看: 393|回复: 0
RE46C190演示板
  • 签到天数: 361 天
    发表于 2013-12-26 14:26:41 | 显示全部楼层 |阅读模式
    RE46C190演示板是一个完全独立的烟雾探测器的应用与烟室模拟器。The demo board is a complete stand-alone smoke detector application with a smoke chamber emulator. The demo board allows evaluation of all the functions of the RE46C190. Key test points of the device are available at the bottom edge of the demo board. It is designed for battery operation using a CR123A battery or can be operated using a power supply. The RE46C190 application circuit is on the right side of the board by the battery holder and piezo horn and the smoke chamber emulator is on the left. The smoke chamber emulator can be disconnected from the application circuit and a photo smoke chamber or its components can be connected to the demo board. This Kit Contains:• One RE46C190 Photo Smoke Detector Demo Board• Preprogrammed RE46C190 parts• Knob and standoffs for final board assemblyFeatures:• The demo board allows quick and easy evaluation of the RE46C190• Typical RE46C190 Application Circuit• Smoke Chamber Emulator• Adjustment for Smoke Density• Adjustment for Low Battery Testing• Preprogrammed parts adjusted for smoke chamber emulator characteristics
    RE46C190 Demo Board (ADM00344) BOM .pdf
    78.65 KB, 下载次数: 0
    RE46C190 Demo Board (ADM00344) Gerbers .zip
    162.14 KB, 下载次数: 0
    RE46C190 Demo Board (ADM00344) Schematic .pdf
    47.26 KB, 下载次数: 0
    RE46C190 Demo Board Users Guide .pdf
    500.57 KB, 下载次数: 0
    GMT+8, 2025-1-16 10:55 , Processed in 0.114041 second(s), 16 queries , MemCache On.
