查看: 814|回复: 0
DM240314 LCD Explorer开发板
  • 签到天数: 361 天
    发表于 2013-12-26 11:11:39 | 显示全部楼层 |阅读模式
    DM240314 LCD Explorer开发板支持芯片的与微控制器的x8公用段LCD驱动器。The LCD Explorer Development Board supports Microchip’s 100-pin Microcontrollers with x8 common Segment LCD Drivers. The LCD Explorer provides an ideal platform for a customer to evaluate a MCU with a x8 Common LCD Driver on a 38 segment x 8 common LCD display. PICtail Plus connections allow a customer to evaluate the selected MCU in a complex system by adding Microchip’s PICtail Plus daughter boards.Features Supports all 100-pin LCD Processor Plug-In Modules (PIM)Includes 100-pin PIC24FJ128GA310 LCD PIM96 Segment 37 Segment x 8 Common LCD GlassSupport 1/3 Biasing with:External resistor ladderInternal resistor ladderCharge pump biasing with capacitor 4 Buttons and 1 mTouch Capacitive ButtonAnalog potentiometer and temperature sensorPower input from 9V power supply, battery or USB power sourceSeparate Vbat battery supplySingle UART communication channel via USB bridgeRJ11 and 6 pin PICkit™ 3 programming and debug connectorsPICtail™ Plus Vertical and Horizontal connections All Pins populated with many used for other functions on boardUpper slot is open for use by end user Package ContentsLCD Explorer Development Board100-pin PIC24FJ128GA310 LCD PIMExample software programmed on PIMInformation Sheet
    AN1428, LCD Biasing and Contrast Control Methods .pdf
    352.28 KB, 下载次数: 0
    Introducing the LCD Explorer Demonstration Board Info Sheet .pdf
    631.77 KB, 下载次数: 0
    LCD Explorer Development Board .zip
    682.65 KB, 下载次数: 0
    GMT+8, 2025-1-16 11:08 , Processed in 0.117769 second(s), 16 queries , MemCache On.
